W
WLS
Dobrý den.Ia m s připojením problém pin moci pad VDD3IP.Pokud jde o pin pro vdd3 *!a GND *!je připojen, ale ne pro pin pro napájení a země-core.
Jak nastavit na port připojen k základní výkon / zemi?
Thx./********** LEF **************************/
MACRO VDD3IP
TŘÍDA PAD;
ZAHRANIČNÍ VDD3IP 0,00 -5,40;
PŮVOD 0,00 5,40;
VELIKOST 100,00 BY 340,40;
Symetrie xy R90;
STRÁNEK ioSite_P;
PIN
DIRECTION INOUT;
USE moci;
PORT
VRSTVA MET2;
RECT 11,60 331,00 88,40 335,00;
VRSTVA MET3;
RECT 5,50 3,05 94,85 92,00;
END
END
PIN gnd3o!
USE zemi;
SHAPE FEEDTHRU;
PORT
VRSTVA MET3;
RECT 0,00 100,00 4,00 174,60;
RECT 96,00 100,00 100,00 174,60;
END
END gnd3o!
PIN vdd3o!
USE moci;
SHAPE FEEDTHRU;
PORT
VRSTVA MET3;
RECT 0,00 177,60 4,00 252,20;
RECT 96,00 177,60 100,00 252,20;
END
END vdd3o!
PIN vdd3r2!
USE moci;
SHAPE FEEDTHRU;
PORT
VRSTVA MET3;
RECT 0,00 255,70 4,00 280,70;
RECT 96,00 255,70 100,00 280,70;
END
END vdd3r2!
PIN gnd3r!
USE zemi;
SHAPE FEEDTHRU;
PORT
VRSTVA MET3;
RECT 0,00 282,60 4,00 312,60;
RECT 96,00 282,60 100,00 312,60;
END
END gnd3r!
PIN vdd3r1!
USE moci;
SHAPE FEEDTHRU;
PORT
VRSTVA MET3;
RECT 0,00 314,45 4,00 334,45;
RECT 96,00 314,45 100,00 334,45;
END
END vdd3r1!
OBS
VRSTVA MET3;
RECT 0 -5,4 100 335;
VRSTVA MET1;
RECT 0,30 -5,10 99,70 334,70;
VRSTVA MET2;
RECT 89,00 -5,10 99,70 334,70;
RECT 0,30 -5,10 11,00 334,70;
RECT 11,00 -5,10 89,00 330,40;
END
END VDD3IP
MACRO VDD3IP
TŘÍDA PAD;
PŮVOD 0,00 5,40;
Symetrie xy R90;
STRÁNEK ioSite_P;
PIN
DIRECTION INOUT;
USE moci;
PORT
VRSTVA MET2;
VRSTVA MET3;
END
END
PIN gnd3o!
USE zemi;
SHAPE FEEDTHRU;
PORT
VRSTVA MET3;
END
END gnd3o!
PIN vdd3o!
USE moci;
SHAPE FEEDTHRU;
PORT
VRSTVA MET3;
END
END vdd3o!
PIN vdd3r2!
USE moci;
SHAPE FEEDTHRU;
PORT
VRSTVA MET3;
END
END vdd3r2!
PIN gnd3r!
USE zemi;
SHAPE FEEDTHRU;
PORT
VRSTVA MET3;
END
END gnd3r!
PIN vdd3r1!
USE moci;
SHAPE FEEDTHRU;
PORT
VRSTVA MET3;
END
END vdd3r1!
OBS
VRSTVA MET3;
VRSTVA MET1;
VRSTVA MET2;
END
END VDD3IP
