Jak mohu nastavit operační zesilovač
X
xdyrick
Jak můžete vidět z následující text MOSFET vše v So.ale operační zesilovač má zisk-2dB, jak mohu nastavit jim umožní získat větší stát
subckt
element 0: mm7 0: MM5 0: mm4 0: MM6 0: mm11 0: mm10
model 0: p3v 0: p3v 0: p3v 0: p3v 0: n3v 0: n3v
region Saturati Saturati Saturati Saturati Saturati Saturati
id-5.9591u-11.0956u-11.0956u-5.9591u 5.9591u 5.9591u
IBS 2.4563f 3.214e-20-20 3.214e 2.4563f-2.005e-21-2.005e-21
IBD 4.9951f 3.4532f 3.4532f 4.9951f-59.5594a-59.5594a
VGS -1,0718 -1,0500 -1,0500 -1,0718 850,0000m 850.0000m
VDS- 235.1159m- 228.1767m-228.1767m-235.1159m 313.1664m 313,1664m
vbs 228,1767m 0.0.228,1767 m 0.0.
V.- 885.9850m-840,6536m- 840.6536m-885,9850m 622.6604m 622,6604m
vdsat- 204.9377m- 220.9339m-220,9339m-204,9377m 217.6919m 217,6919m
beta 334.0794u 524.9302u 524.9302u 334.0794u 234.0114u 234.0114u
GAM eff 350,8455m 350.4868m 350,4868m 350.8455m 703,3935m 703,3935m
GM 50.8340u 84.1471u 84.1471u 50.8340u 44.0752u 44.0752u
GDS 5.8549u 13.6127u 13.6127u 5.8549u 1.2973u 1.2973u
GMB 8.5821u 15.8838u 15.8838u 8.5821u 15.6347u 15.6347u
cdtot 11.5162f 19.6407f 19.6407f 11.5162f 2.7659f 2.7659f
cgtot 24.1660f 37.3839f 37.3839f 24.1660f 6.4646f 6.4646f
cstot 32.6768f 52.6794f 52.6794f 32.6768f 8.6611f 8.6611f
cbtot 25.7887f 42.4298f 42.4298f 25.7887f 8.4276f 8.4276f
ČGS 20.8204f 32.3715f 32.3715f 20.8204f 4.5719f 4.5719f
CGD 1.1971f 2.2221f 2.2221f 1.1971f 242.7163a 242.7163asubckt
element 0: mm9 0: MM8 0: mm3 0: mm2 0: MM1
model 0: n3v 0: n3v 0: n3v 0: n3v 0: n3v
id 5.9591u 5.9591u 10.2731u 5.1366u 5.1366u
IBS-294.8778a-294.8778a-2.551e-21-35.9093a-35.9093a
IBD-1.4470f-1.4470f-59.6094a-289.2447a-289.2447a
VGS 786.8336m 786.8336m 850.0000m 1.2800 1.2800
VDS 1,2235 1,2235 1,5519 1,5519 219,9544 m
vbs-313,1664m-313,1664m 0.-219.9544m- 219.9544m
V. 765.2300m 765,2300m 641.2358m 638,8488m 638,8488m
vdsat 85.3907m 85.3907m 205,1740m 553,8381m 553,8381m
beta 2,4804 m 2,4804 m 476.0728u 28.3763u 28.3763u
GAM eff 703,9373m 703,9373m 703,3935m 703,7839m 703,7839m
GM 104.6919u 104.6919u 80.0055u 14.7931u 14.7931u
GDS 244.2669n 244.2669n 4.6812u 37.5718n 37.5718n
GMB 33.4104u 33.4104u 28.9888u 4.5984u 4.5984u
cdtot 16.7024f 16.7024f 5.5850f 1.4659f 1.4659f
cgtot 45.8552f 45.8552f 12.3067f 20.8501f 20.8501f
cstot 61.1117f 61.1117f 16.9347f 19.6372f 19.6372f
cbtot 54.0396f 54.0396f 14.7215f 14.6562f 14.6562f
ČGS 33.4331f 33.4331f 9.4549f 13.5439f 13.5439f
CGD 2.0605f 2.0605f 728.7084a 125.6004a 125.6004a
Bez pohledu na schéma, mohu si jen pár věcí, které mohou zabít vaše zisk.
1) Vy používáte AC analýzu na frekvenci, která daleko přesahuje vašeho zesilovače na šířku pásma.
2) Jste možná snaží řídit při odporovém zatížení a výstupní impedance je příliš vysoká.
3) Děláš nějaký legrační zpětnou vazbu k tlumení zisk.
Nicméně, při pohledu na vaše mosfet DC Provozní bodů, GM na všechny z nich jsou velmi malé.Největší z nich vidím, je ~ 100uS.I když jsou všechny v nasycení, tam je asi nějaký problém, který ovlivnění brání v získání hodnoty GM, které hledáte.
Myslím, že AC analýza je provedena za nevhodné zaujatost condictions na vstupní svorky.
Za předpokladu, že váš zesilovač je definována jako SUBCKT takto
.SUBCKT operační zesilovač in_n in_p ven
. KONEC
Provést následující zpětnou vazbu provést řádnou analýzu AC
Xopamp in_n in_p z operační zesilovač
* Zpětná vazba DC s AC zabijáka
LFB ven in_n 10e10
CFB in_n 0 10e10
Vin in_p 0 VDD / 2 AC 1
Zpětná vazba DC Vám zaručuje okruh je prepperly neobjektivní.
Mám post obrázek jako uchycení, ale nevyšel
já nemám právo přiložit uchycení, nebo jsem udělal špatně!
může mi někdo pomoci?
