Ahoj dělám čítač ve vhdl ale píše mi chybu 10821
"Error (10821): HDL error at count.vhd(20): can't infer register for "cnt[0..8]" because its behavior does not match any supported register model"
nevím co s tím
muj code
nevím co s tím
muj code
entity count is
port
clock : in std_logic;
load : in std_logic;
reset : in std_logic;
enable : in std_logic;
q : out integer range 0 to 256
end entity;
architecture behav of count is
begin
process (clock,load,reset,enable)
variable cnt: integer range 0 to 256;
begin --rising_edge funkce pro náběžnou hranu
if (rising_edge(clock)) then
if reset = '1' then
cnt := 0;
elsif load='0' then
cnt:= 128;
elsif (rising_edge(enable)) then
cnt := cnt + 1;
end if;
end if;
q <= cnt;
end process;
end behav;
