Sound on my new radio is muffled....
In sci.electronics.repair, on 22 Sep 2023 18:36:58 GMT, rbowman
<bowman@montana.com> wrote:
On Fri, 22 Sep 2023 13:42:01 -0400, micky wrote:
I bought a $230 wifi radio that is impressive in many ways, but the
problem I have is that the sound sounds muffled
Did you take it out of the Amazon box first?
I took the cord out.
It\'s brand new. I don\'t want to scuff it.
https://www.amazon.com/gp/product/B0BG67YH18/
In sci.electronics.repair, on Fri, 22 Sep 2023 18:01:01 -0400, legg
<legg@nospam.magma.ca> wrote:
On Fri, 22 Sep 2023 13:42:01 -0400, micky <NONONOmisc07@fmguy.com
Maybe it\'s okay for music. I haven\'t listened to much music, but for
talk it sounds muffled. Like literally they are talking through some
sort of muffle. I don\'t have this problem with 5 other table radios.
Is the problem that there is too much bass? If not that, what?
It has equalizer settings so I changed from default and various kinds of
music to \"talk\". I didnt\' hear any change.
So I went to custom, which has 6 frequency ranges, and over time, I\'ve
lowered the lowest 4 ranges to the minimum and raised the top one to the
max, and the one in between almost to the max. This helped at first,
but future changes were smaller and I didn\'t see addtional help.
I can still understand if I make the sound one or two steps louder, but
then it\'s louder than I want.
Is there an audio ng that\'s not dormant that I can post too. alt.audio
and alt.audio.pro had gone 3 years without posts.
Make and model number.
RL
On Fri, 22 Sep 2023 15:10:51 -0400, Retirednoguilt wrote:
Time for a visit to an audiologist. If you don\'t use hearing aids, you
may need them. If you use them, the settings may need to be tweaked. A
few years ago, I thought something had gone wrong with my stereo
equipment, either the speakers or the receiver.
Considering two (out of thirteen) of the Amazon reviews complained about
the sound and one said a speaker was DOA I\'d lean toward the problem not
being with micky\'s ears.
On Fri, 22 Sep 2023 16:26:39 -0400, micky wrote:
4.1 on 24 ratings. That\'s pretty good and I think we\'ve all seen
reviews, of restaurants too, where one person says it was terrible and
the other says 5 stars. So i didn\'t worry too much about reviews,
mostly because iirc this and one other they themselves sell were the
only wifi radios with presets. And presets was a deal-breaker,
especially since wifi radios can\'t scan
Yeah but 2 out of the 13 written reviews complained about the sound. With
that small a sample I pay more attention to the negative reviews.
On a sunny day (Fri, 22 Sep 2023 13:42:01 -0400) it happened micky
<NONONOmisc07@fmguy.com> wrote in
<gojrgilsq36fjgt7gca1r8d0v6pbscg6bo@4ax.com>:
Is there a headphone connector?
If it sounds OK on headphones then the speaker / acoustics of the cabinet is bad.
Use external speaker? or dump it in the garbage, give it away?
On 22 Sep 2023 23:00:58 GMT, lowbrowwoman, the endlessly driveling,
troll-feeding, senile idiot, blabbered again:
Ah, you looked it up, again, just like everything else (all your several
digit numbers, your endless detailed data, etc.) you keep posting and
bragging about. I understand that you STILL will be claiming you are holding
down a job, right? LOL
Another one of the resident senile bigmouth\'s idiotic \"cool\" lines:
\"If you\'re an ax murderer don\'t leave souvenir photos on your phone.\"
\"MID: <k7ssc7F8mt9U3@mid.individual.net>\"
Perhaps tweeter, or midrange driver missing or defective.
perhaps speaker cone is crooked and hung up. perhaps someone was
smuggling illict substances in the speaker box and for reasons
was unable to retreive them, and you have the result.
Have you tried headphones, does that improve the sound? If it sounds
good with headphones the problem is probably inside the speaker box.
Jasen.
🇺🇦 Слава Україні
On 9/22/2023 4:32 PM, micky wrote:
In alt.home.repair, on Fri, 22 Sep 2023 15:10:51 -0400, Retirednoguilt
equipment, either the speakers or the receiver. I also noticed I was
having problems understanding dialog on the TV and in face to face
conversations. Turns out I have typical \"mild-moderate\" age-related
hearing loss. Hearing aids made a big difference in what I hear and
almost completely \"repaired\" my stereo system. If you will be getting
your first set, make sure they come with a 100% money-back guarantee if
not satisfied, for at least 45-60 days as it takes a little while for
your brain to adjust. Much longer than it takes to adjust to a new
eyeglasses prescription.
What brand did you get and about how much were they?
Do you have to have them \"tuned\" by the audiologist? Just once or every
year or something?
I have a set of ReSound Linx Quatro hearing aids that were recommended
by my audiologist at Walter Reed. I got them about 4 years ago. Yes,
they were custom tuned. Initially set to compensate for my audiogram
and then tweaked by my subjective comments. They retailed at that time
for about $5K so I\'m told. Being retired military, I qualify for the
DoD\'s hearing aids at cost program. My total cost out of pocket was
about $850. The audiologist recommended an annual checkup or anytime
sooner if a problem develops.
Reading some of your other comments in this thread, it seems that you
don\'t have a complaint of muffled sound when listening to other radios.
If that\'s the case, and the other radios have a similar audio frequency
response, your problem may not be your hearing. Perhaps it is the
radio. Good luck!
> Do you sleep with them?
On Fri, 22 Sep 2023 18:33:25 -0400, micky <NONONOmisc07@fmguy.com>
snip
Suggest you scroll through the various equalizer presets
available, to see if a usable difference is noted.
A factory default is offered.
It\'s possible that there\'s harness error/damage off
the production floor.
Return it if not satisfied.
RL
le...@nospam.magma.ca> wrote:
On Fri, 22 Sep 2023 13:42:01 -0400, micky <NONONO...@fmguy.com
RL
Others have complained about the sound. From different reviewers:
\"I also did not enjoy the way this radio sounded at all! I spent several hours listening to a wide array of stations and musical styles while trying to adjust the EQ settings, but could not find any tolerable balance whatsoever. The equalizer is quite limited and did not seem to make a significant difference in changing the overall sound quality, which was muddled and lacking in detail, while also making my ears really, really tired and sore.\"
and:
\"However, sound quality is very muddy. It has plenty of volume and hood thumping bass, but the high end is just not there, regardless of EQ settings.\"
Sounds to me like this is the way this radio sounds - again, tuned for the lowest common denominator. I don\'t think you\'ll ever be happy with it. I\'d return it.
In alt.home.repair, on Sat, 23 Sep 2023 09:20:21 -0400, Retirednoguilt
year or something?
radio. Good luck!
I think it\'s the radio too, but I do have an interest in hearing aids. I
hear about 80% of the people I meet fine, but some talk so low I can\'t.
And at meetings, but those are not as common anymore. At home with zoom
I can just turn up the volume. And at movies.
I have a $150 \"hearing amplifer\" and it works well at my current level
of hearing. Although it has a good design, they seem to have used a
cheap on/off switch and sometimes when I turn it off it stays on and
vice versa. It\'s just a slide switch, but embedded in hard rubber so I
can\'t replace it. Maybe I\'m getting more used to it, although... I can
understand the voice when it says \"Power off\" or \"Power on\" but after
she says On she says something else and I can\'t come close to
understanding. (In this casee, it is not about my hearing, but about
the device.)
I like the onse with a yoke, so when they fall out of my ears as they
often do, I don\'t lose them. None of the high quality hearing aids
like yours or the Otikon that Clare mentinoed come in yoke form, do
they?
In alt.home.repair, on Sat, 23 Sep 2023 11:27:46 -0000 (UTC), Jasen
The grill cloth is square, 4 or 5\". Probably no separate tweeter and
for some reason I think it\'s probably not coaxial.
Hmmm. Maybe. Either way I should open it up and look.
perhaps someone was
I\'d have to find a place to sell that stuff, but maybe I coudl get some
of my purchase price back. Radio probably made in China. Opium or
something related.
Good idea. i should have thought of that.
Writing my previous post, bluetooth output occurred to me. Going to try
that now.
Well, the Grace had already found and would pair with/connect to my
computer which is more than 40 feet away, farther than I thought normal
bluetooth range was, but it won\'t find the Sangean radio which is one
foot above it. The Sangean Bluetooth is still working because it paired
with Alexa as soon as I put the radio on Bluetooth. In fact, I
unplugged Alexa to keep it/her from interfering.
So I\'m fairly sure I can get this to work, but I need some time to think
about it.
In alt.home.repair, on Sat, 23 Sep 2023 06:13:08 GMT, Jan Panteltje
Ah, a great suggestion. I think so, in the back. With a small jack. I
have to find my headset with the small plug. It\'s cheap too so maybe I
should go straight to***
I never dump anything in the garbage, but I\'ll admit, when I offered
some computer speakers with terrible sound, and I said they might be
good for children because they had terrible sound, no one replied.
>give it away?
There still isn\'t a Wifi radio with everything I want. One or two
others do have presets, but each one has somet hing I don\'t like.
External speakers sounds good. *** It might have bluetooth output**
and I could send it to the AM/FM radio^^ on the shelf above that does
have bluetooth input. It won\'t have stereo but I can live without that.
Mostly I listen to talk anyhow. **The manual says \"Integrated
bluetooth... transmitter to stream to Bluetooth headsets. ... Bluetooth
audio to every room in your house\".
It can work as transmitter or receiver but not both at the same time. --
that\'s fine.
about it.
^^The Sangean WR-22 AM/FM radio on the shelf above has good sound even
though it sells even 3.8 years later for $149.
I bought a cheap early version of Alexa, the one that\'s shaped like a
cylinder of Quaker, and it only has 10 levels of volume and usually none
were the right one, so I send it to this radio that has 30 levels of
volume. That works okay but I\'d rather just push a button than have to
yell, Alexa play CNN for two hours
In sci.electronics.repair, on Fri, 22 Sep 2023 15:08:54 -0700, Bob F
<bobnospam@gmail.com> wrote:
Have you
tried \"stations\"?
There are lots of apps to do this with your phone, and probably plenty
for PC\'s,
The PC is at the far end of the hall, and when in bed, I don\'t want to
go there to change stations. With the regular radio, I change stations
a lot. Sometimes back and forth and back and forth.
The phone could be by my bed, but in practice the phone is off unless
I\'m going somewhere. And then off again when I get home. I\'ve used
the phone for this sort of thing while travelling and in the car, and
it\'s just not as easy as pushing a button
as an alternative. Is there a satisfaction warranty for this
\"radio\" so you can send it back and try alternatives?
I may have let too much time go by. I\'m over the month that Amazon
gives, but I did it pretty much knowing there was nothing else I wanted.
BTW, when I sent in my last suggestion for firmware improvement, I
mentioned in passing that I haven\'t found CNN or MSNBC yet. She still
volunteered that I could find CNN among the IHeart entries, by typing
in, on the radio, CNN, and it worked. (I already quoted that she said
MSNBC change their stream name frequently!)
I\'ve sent in two suggestions, to delink the Sleep function from most of
the other controls, and to add a Seek function.
I\'m saving complaining about the sound for last, I\'m not sure why. Maybe
they\'ll like me because I\'ve been so helpful (although why they didnt\'
think of Seek I do not know. Maybe they have.) I guess the worst would
be moving it to the kitchen, where I don\'t mind if the sound is louder.
I use StreamWriter on my PC to automatically store my favorite FM
programs, like the \"Saturday Traditions\" and \"Thom Hartmann\" shows on KBCS.
I\'m looking at its webpage now. Very good, and free. Thanks.
In sci.electronics.repair, on Fri, 22 Sep 2023 13:42:01 -0400, micky
I\'m trying to connect my wifi radio to a regular radio with bluetooth.
The Grace wifi radio doesn\'t find the Sangrean wr-22, even though it has
found my laptop, even though the laptop has never been on and closer
than 40+ feet from the Wifi radio. And it later found something called
[LG]webOSnnnnnnn which must be in my neighbor\'s house.
But not the Sangrean which only 12 inches above the Wifi.
Is there any chance Grace wifi radio knows how to find headphones, but
not another wifi radio????
The owners manual only mentions headphones but I took that to be becuase
that\'s the standard device and my problem was not foreseen. The
Sangrean works fine when receiving audio from Alexa. Connects very
easily and quickly.
In sci.electronics.repair, on Sat, 23 Sep 2023 23:43:05 -0400, micky
I let it try for hours, but the Grace wifi never found the Sangrean.
easily and quickly.
If I can\'t connect by bluetooth, there is a Line Out on the Grace and a
Aux In on the Sangrean. Both Stereo**. Are those of the same
amplitude? Will that work? The Aux In says connect, for example, an
iPod, MP3 or CD player. Are their outputs like Line Out would be?
There also a 3.5mm mini headphone jack on the sending radio. Would that
be better than Line Out.
**Even though the Sangrean has only one speaker, it has a stereo Aux In
jack. Do you think that means L and R are merged in the radio?
Or can I merge the left and right channels just by buying the right
Y-cable? Is there a name for that?
year or something?
radio. Good luck!
the device.)
they?
I don\'t know. Mine have never fallen out.
easily and quickly.
Line out outputs tend to be a fixed output level, not affected by the
volume control. The volume resulting at the receiving device may be at a
different level than the receiving device default, but the volume
control should adjust for that unless the receiving device expects a
significantly different level. The headphone output would allow the
outputting device volume to be adjusted if the line outs are not
compatible for some reason. If the output is too high for the inputting
device, distortion will result.
I would use the line out as my first choice.
You really should talk to the seller of your device about replacing it
with one that actually works or refunding your money..
Probably.
In alt.home.repair, on Sun, 24 Sep 2023 07:44:48 -0700, Bob F
easily and quickly.
OKay. I like that better because the jacks are in the back.
Even though the fidelity of $8 earbuds can\'t be that good, I tried them
last night in the headphone jack, but they have a 2.5mm plug to fit a
cell phone and it\'s a 3.5 mm jack. Plus it\'s TRRR instead of TRR,
because of the mike it has. Iirc that is still supposed to work if the
plug fit.
I guess I\'m afraid they\'ll send me another one that\'s no better than
this.
After I\'ve gone to the work of shipping the first one back and putting
the new one in its place, both of which would have been pretty easy 2
years ago but now seem like tiring acts.
Also I think it would be easier to get them to send a new one after I
tell them how much effort I put in to get this one to work. This stuff
doesn\'t seem tiring because it fulfills my curiosity too.
Probably.
I hope so.
BTW, I remembered last night that I have another bluetooth radio, also
by Sangean, in the bathroom, and I tried to pair it with the Grace radio
this morning and it was easy. So I don\'t know why I can\'t pair the
bedroom Sangean, especially since I can easily with Alexa, and I
unplugged Alexa. It\'s not just that I can\'t pair it, the bedroom
Sangrean doesn\'t even show up on the Grace wifi list of bluetooth
sources.
In alt.home.repair, on Sun, 24 Sep 2023 06:40:44 -0400, Retirednoguilt
they?
That\'s great!
